Community Member
3750 & 3845 connectivity issue
hi All,
I have Cisco 3750 24 + 2SFP connects to cisc 3845 router using SFP ( both Cisco). The link is up and I can ping to the router. However when I reload the router, the SFP switch port is down. I need to enable switch port to bring it up.
Does anyone know what would be the cause?
thanks
1 REPLY
Purple
Re: 3750 & 3845 connectivity issue
I'll ask the simple question first , when you bring the switchport up you are doing a copy run start command correct ? If not the next time you reload the switchport will be in the down condition again.
162
