I would like to use 2950 series as layer 2 and WS-C3750G-48PS as layer 3 switches. If I use SFP ports using copper SFP modules on 3750 switch to provide uplink, can I use 2950 switch? If so,
which 2950 switch (one which is not in end-of-sale and support) should I order to provide the uplink to 3750 switch?
what is the part number should I order for Copper SFP module on 3750 switch?
If I cannot use 2950 series, what other switch can I use to provide uplink to 3750 SFP module.
Or can I provide normal uplink between 2950 and 3750 fast ethernet ports without using SFP modules as I understand its good to use gig ports as uplinks.
please help asap
thanks
sarat
