02-24-2012 12:55 PM - edited 03-07-2019 05:10 AM
Haveing issue with DHCP server handing out IP addresses to client connected to VLAN5 interface.....
ISP Router>Firewall -(WatchGuard Drop-in mode)
I have several 3750 switches and one acting as a L3 switch. The L3 is configured as follow:
interface Vlan1
ip address 10.100.0.4 255.255.248.0
interface Vlan5
ip address 10.100.8.2 255.255.248.0
ip helper-address 10.100.0.16 (This is a windows 2008 DHCP server scoped for 10.100.0.10-254 and 10.100.8.10.-254)
ip default-gateway 10.100.0.1
ip classless
ip route 0.0.0.0 0.0.0.0 10.100.0.1
ip http server
ip http secure-server
Here is the switch where the server resides:
interface FastEthernet1/0/10
description test VLAN5
switchport access vlan 5
switchport mode access
storm-control broadcast level 10.00
macro description cisco-desktop
spanning-tree portfast
spanning-tree bpduguard enable
If I connect a laptop to int fa1/0/10 I DO NOT get an IP address from the 10.100.0.8 scope. If I connect to another interface within the VLAN 1, I get an address from the 10.100.0.0 range.
Solved! Go to Solution.
02-27-2012 06:50 AM
Hugh,
The DHCP server is in VLAN 1 === 10.100.0.16
You need a seperate SCOPE definitely not under this SUPERSCOPE
When you are using multiple VLANS you can not use SUPERSCOPES
Alex
02-24-2012 02:03 PM
Hugh,
Have you set the dhcp scopes as a superscope.
If yes then remove the superscope and leave the scopes as stand alone
Alex
02-27-2012 06:00 AM
Have dhcp server set as super scope and don't experience any problems with VLAN1. Any reason why it would only affect vlan 5? Thanks for the reply!
02-24-2012 04:31 PM
How are these two switches connected. For vlan 5 from the fa switch to get to the l3 switch, you'll need a trunk port connecting them that bellows vlan 5
02-27-2012 06:50 AM
Hugh,
Alex
02-27-2012 07:35 AM
I will give it a try. Here is my wireshark output.
No. Time Source Destination Protocol Info
25 3.916883 10.100.8.2 10.100.0.16 DHCP DHCP Discover - Transaction ID 0xa6dd94f1
Frame 25: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits)
Arrival Time: Feb 27, 2012 10:21:48.336980000 Eastern Standard Time
Epoch Time: 1330356108.336980000 seconds
[Time delta from previous captured frame: 0.073777000 seconds]
[Time delta from previous displayed frame: 0.000000000 seconds]
[Time since reference or first frame: 3.916883000 seconds]
Frame Number: 25
Frame Length: 342 bytes (2736 bits)
Capture Length: 342 bytes (2736 bits)
[Frame is marked: False]
[Frame is ignored: False]
[Protocols in frame: eth:ip:udp:bootp]
[Coloring Rule Name: UDP]
[Coloring Rule String: udp]
Ethernet II, Src: Cisco_71:95:40 (00:1d:a2:71:95:40), Dst: Dell_42:23:c6 (00:18:8b:42:23:c6)
Destination: Dell_42:23:c6 (00:18:8b:42:23:c6)
Address: Dell_42:23:c6 (00:18:8b:42:23:c6)
.... ...0 .... .... .... .... = IG bit: Individual address (unicast)
.... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
Source: Cisco_71:95:40 (00:1d:a2:71:95:40)
Address: Cisco_71:95:40 (00:1d:a2:71:95:40)
Type: IP (0x0800)
Internet Protocol, Src: 10.100.8.2 (10.100.8.2), Dst: 10.100.0.16 (10.100.0.16)
Version: 4
Header length: 20 bytes
Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00)
0000 00.. = Differentiated Services Codepoint: Default (0x00)
.... ..0. = ECN-Capable Transport (ECT): 0
.... ...0 = ECN-CE: 0
Total Length: 328
Identification: 0x00fd (253)
Flags: 0x00
0... .... = Reserved bit: Not set
.0.. .... = Don't fragment: Not set
..0. .... = More fragments: Not set
Fragment offset: 0
Time to live: 255
Protocol: UDP (17)
Header checksum: 0x9cce [correct]
[Good: True]
[Bad: False]
Source: 10.100.8.2 (10.100.8.2)
Destination: 10.100.0.16 (10.100.0.16)
User Datagram Protocol, Src Port: bootps (67), Dst Port: bootps (67)
Source port: bootps (67)
Destination port: bootps (67)
Length: 308
Checksum: 0x4b57 [validation disabled]
[Good Checksum: False]
[Bad Checksum: False]
Bootstrap Protocol
Message type: Boot Request (1)
Hardware type: Ethernet
Hardware address length: 6
Hops: 1
Transaction ID: 0xa6dd94f1
Seconds elapsed: 11
[Expert Info (Note/Malformed): Seconds elapsed (11) appears to be encoded as little-endian]
[Message: Seconds elapsed (11) appears to be encoded as little-endian]
[Severity level: Note]
[Group: Malformed]
Bootp flags: 0x0000 (Unicast)
0... .... .... .... = Broadcast flag: Unicast
.000 0000 0000 0000 = Reserved flags: 0x0000
Client IP address: 0.0.0.0 (0.0.0.0)
Your (client) IP address: 0.0.0.0 (0.0.0.0)
Next server IP address: 0.0.0.0 (0.0.0.0)
Relay agent IP address: 10.100.8.2 (10.100.8.2)
Client MAC address: Dell_51:39:c6 (00:15:c5:51:39:c6)
Client hardware address padding: 00000000000000000000
Server host name not given
Boot file name not given
Magic cookie: DHCP
Option: (t=53,l=1) DHCP Message Type = DHCP Discover
Option: (53) DHCP Message Type
Length: 1
Value: 01
Option: (t=116,l=1) DHCP Auto-Configuration = AutoConfigure
Option: (116) DHCP Auto-Configuration
Length: 1
Value: 01
Option: (t=61,l=7) Client identifier
Option: (61) Client identifier
Length: 7
Value: 010015c55139c6
Option: (t=50,l=4) Requested IP Address = 10.100.1.123
Option: (50) Requested IP Address
Length: 4
Value: 0a64017b
Option: (t=12,l=9) Host Name = "HWY-11248"
Option: (12) Host Name
Length: 9
Value: 4857592d3131323438
Option: (t=60,l=8) Vendor class identifier = "MSFT 5.0"
Option: (60) Vendor class identifier
Length: 8
Value: 4d53465420352e30
Option: (t=55,l=11) Parameter Request List
Option: (55) Parameter Request List
Length: 11
Value: 010f03062c2e2f1f21f92b
1 = Subnet Mask
15 = Domain Name
3 = Router
6 = Domain Name Server
44 = NetBIOS over TCP/IP Name Server
46 = NetBIOS over TCP/IP Node Type
47 = NetBIOS over TCP/IP Scope
31 = Perform Router Discover
33 = Static Route
249 = Private/Classless Static Route (Microsoft)
43 = Vendor-Specific Information
Option: (t=43,l=2) Vendor-Specific Information
Option: (43) Vendor-Specific Information
Length: 2
Value: dc00
End Option
26 3.917053 10.100.0.16 10.100.8.2 DHCP DHCP Offer - Transaction ID 0xa6dd94f1
Frame 26: 344 bytes on wire (2752 bits), 344 bytes captured (2752 bits)
Arrival Time: Feb 27, 2012 10:21:48.337150000 Eastern Standard Time
Epoch Time: 1330356108.337150000 seconds
[Time delta from previous captured frame: 0.000170000 seconds]
[Time delta from previous displayed frame: 0.000170000 seconds]
[Time since reference or first frame: 3.917053000 seconds]
Frame Number: 26
Frame Length: 344 bytes (2752 bits)
Capture Length: 344 bytes (2752 bits)
[Coloring Rule Name: Checksum Errors]
[Coloring Rule String: cdp.checksum_bad==1 || edp.checksum_bad==1 || ip.checksum_bad==1 || tcp.checksum_bad==1 || udp.checksum_bad==1 || mstp.checksum_bad==1]
Ethernet II, Src: Dell_42:23:c6 (00:18:8b:42:23:c6), Dst: Cisco_71:95:40 (00:1d:a2:71:95:40)
Destination: Cisco_71:95:40 (00:1d:a2:71:95:40)
Source: Dell_42:23:c6 (00:18:8b:42:23:c6)
Type: IP (0x0800)
Internet Protocol, Src: 10.100.0.16 (10.100.0.16), Dst: 10.100.8.2 (10.100.8.2)
Version: 4
Total Length: 330
Identification: 0x250f (9487)
Flags: 0x02 (Don't Fragment)
.1.. .... = Don't fragment: Set
Fragment offset: 0
Time to live: 128
Protocol: UDP (17)
Header checksum: 0x0000 [incorrect, should be 0xb7ba]
[Good: False]
[Bad: True]
[Expert Info (Error/Checksum): Bad checksum]
[Message: Bad checksum]
[Severity level: Error]
[Group: Checksum]
Source: 10.100.0.16 (10.100.0.16)
Destination: 10.100.8.2 (10.100.8.2)
Length: 310
Checksum: 0x1e21 [validation disabled]
Bootstrap Protocol
Message type: Boot Reply (2)
Hops: 0
Seconds elapsed: 0
Your (client) IP address: 10.100.1.123 (10.100.1.123)
Next server IP address: 10.100.0.16 (10.100.0.16)
Magic cookie: DHCP
Option: (t=53,l=1) DHCP Message Type = DHCP Offer
Length: 1
Value: 02
Option: (t=1,l=4) Subnet Mask = 255.255.248.0
Option: (1) Subnet Mask
Length: 4
Value: fffff800
Option: (t=58,l=4) Renewal Time Value = 12 hours
Option: (58) Renewal Time Value
Length: 4
Value: 0000a8c0
Option: (t=59,l=4) Rebinding Time Value = 21 hours
Option: (59) Rebinding Time Value
Length: 4
Value: 00012750
Option: (t=51,l=4) IP Address Lease Time = 1 day
Option: (51) IP Address Lease Time
Length: 4
Value: 00015180
Option: (t=54,l=4) DHCP Server Identifier = 10.100.0.16
Option: (54) DHCP Server Identifier
Length: 4
Value: 0a640010
Option: (t=15,l=10) Domain Name = "encsd.net"
Option: (15) Domain Name
Length: 10
Value: 656e6373642e6e657400
Option: (t=3,l=4) Router = 10.100.0.4
Option: (3) Router
Length: 4
Value: 0a640004
Option: (t=6,l=8) Domain Name Server
Option: (6) Domain Name Server
Length: 8
Value: 0a64000f0a640010
IP Address: 10.100.0.15
IP Address: 10.100.0.16
End Option
02-27-2012 07:54 AM
Thank you very much!!!!
I created a new scope and bingo. It works! Now I am a little confused. For VLAN1, do I need to remove superscope and create just a scope?
02-27-2012 08:15 AM
Hugh,
Superscopes were used a while back when we had to enter more than 1 IP subnet on a single
ethernet segment. In Cisco these were like adding IP address xxxxxx secondary.
Nowadays with multiple vlans we don not use the superscopes
I subnet per vlan etc.
If you had the scope for vlan 5 under the same superscope as vlan 1
then the DHCP server will not allocate the adresses correctly you might get DHCP NAKS all over the place.
To delete the super scope just right click delete.
It will only delete the superscope NOT the scopes it umbrellas.
Alex
Please rate useful posts
