3750 boots ... kinda
I have a 3450G running ipservicesk9-mz.122-50.SE1. This switch had been up for years. I unracked it this morning and fired it up. It comes up and loads the IOS (abbreviated):
flashfs[0]: flashfs fsck took 10 seconds.
...done Initializing Flash.
done.
Loading "flash:c3750-ipservicesk9-mz.122-50.SE1/c3750-ipservicesk9-mz.122-50.SE1.bin"...@@@@@@@@@@@@
File "flash:c3750-ipservicesk9-mz.122-50.SE1/c3750-ipservicesk9-mz.122-50.SE1.bin" uncompressed and installed, entry point: 0x3000
executing...
Image text-base: 0x00003000, data-base: 0x01D00000
Initializing flashfs...
flashfs[1]: 918 files, 16 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32514048
flashfs[1]: Bytes used: 25537024
flashfs[1]: Bytes available: 6977024
flashfs[1]: flashfs fsck took 3 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
Waiting for Stack Master Election...
front_end/ (directory)
extracting front_end/fe_type_1 (34760 bytes)
extracting front_end/fe_type_2 (73104 bytes)
extracting front_end/front_end_ucode_info (86 bytes)
extracting ucode_info (76 bytes)
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: No Cable found on stack port 1
POST: No Cable found on stack port 2
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
cisco WS-C3750G-48TS (PowerPC405) processor (revision C0) with 118784K/12280K bytes of memory.
Processor board ID FOC1011Y3XL
Last reset from power-on
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:17:5A:C5:4C:80
Motherboard assembly number     : 73-9366-08
Power supply part number        : 341-0107-01
Model revision number           : C0
Motherboard revision number     : A0
Model number                    : WS-C3750G-48TS-E
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CAT100712HN
Top Assembly Part Number        : 800-26345-02
Top Assembly Revision Number    : B0
Version ID                      : V02
CLEI Code Number                : CNMWP00ARB
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3750G-48TS     12.2(50)SE1           C3750-IPSERVICESK9-M
¸C
And that's it .... I bang on the keyboard and nada....
Everyone's tags (1)
Hall of Fame Super Gold
Try a different computer.
So what this ended up being was right where I indicated in the output stopped:
¸C
The switch changed the baud rate to 115000. Before that I was using 9600 like always and could see all the output but when it got to the ,C it changed. So, once I changed my baud rate to 115000 I was in.
Re: 3750 boots ... kinda
You can try to isolate the issue.... Try to switch# mode the switch rename the configuration. Then restart.
If it is still not working try to reupload the iOS or try dif. Version but before you upload try to reformat the flash
322
