3750 define max etherchannel link
Hello all,
I'd like to know if there is a way to define the maximum number of bundled ethernet channel on a 3750 switch.
I found the command "lacp max-bundle" but it seems doesn't work on 3750. Is it correct?
Thansk a lot,
Milko
1 REPLY
Re: 3750 define max etherchannel link
"lacp max-bundle" is not supported in 3750.
You can have a maximum of 8 ports per channel and the total number of channels per switch is 48
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/configuration/guide/swethchl.html#wp1275535
841
