3750 dram
dear
I have 3750. i want to check dram how can i do .
Re: 3750 dram
Upendra
All models of 3750 series switches have a DRAM configuration of 128 MB.
you can check this with the Show version command
HTH, rate if it does
Narayan
Re: 3750 dram
Dear,
I tried but i am not able to see. can you tell details
Re: 3750 dram
Hi Upendra,
Have a look at this sh version output
Switch#sh version
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEB4, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 15:47 by yenanh
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWAR
E (fc)
Switch uptime is 3 weeks, 2 days, 1 hour, 39 minutes
System image file is "flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.S
EB4.bin"
cisco WS-C3750G-24PS (PowerPC405) processor (revision C0) with 118784K/12280K by
tes of memory. <<<<<<<<<<<-----
This is DRAM which is 128
Ankur
Re: 3750 dram
Here you go
Check the line cisco WS-C3750G-48TS (PowerPC405) processor (revision C0) with 118784K/12280K bytes of memory.
MS_IP_L3_MIL#sh ver
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWARE (fc)
MS_IP_L3_MIL uptime is 31 weeks, 5 days, 19 hours, 19 minutes
System restarted at 21:15:58 IST Sat Sep 23 2006
System image file is "flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin"
Processor board ID FOC1003Z8HY
Last reset from power-on
16 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:16:C8:69:12:00
Motherboard assembly number : 73-9366-08
Power supply part number : 341-0107-01
Motherboard serial number : FOC100323L6
Power supply serial number : AZS100103BX
Model revision number : C0
Motherboard revision number : A0
Model number : WS-C3750G-48TS-S
System serial number : FOC1003Z8HY
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT09532ABZ
Top Assembly Part Number : 800-25409-02
Top Assembly Revision Number : B0
Version ID : V02
CLEI Code Number : CNMWU00ARB
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750G-48TS 12.2(25)SEB4 C3750-IPBASE-M
Configuration register is 0xF
Narayan
1099
