3750----Flapping between Ports
I am geeting the below erros can some one suggeest me on the same
Nov 16 17:50:28.163 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 18:09:18.119 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 18:23:23.730 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 18:33:01.236 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0007.8462.e3bd in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 19:06:00.646 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 20:12:42.532 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 20:17:33.798 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0007.8462.e3bd in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 20:22:18.026 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0007.8462.e3bd in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 20:41:48.532 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 21:01:10.834 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
Nov 16 21:16:00.251 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.f394.1f3c in vlan 16 is flapping between port Gi2/0/6 and port Po1
regds
ADHI
Hall of Fame Super Bronze
Re: 3750----Flapping between Ports
A device with the same source MAC-Address is connected to multiple switchports on the switch.
Often, this behavior is seen when configuring teaming/etherchannel at one end of the link w/o configuring the same at the other end of the link.
Based on the switchports listed, it seems you have an etherchannel configured in the swith (Port-channel1) but you've connected the device on Port G2/0/6 instead on the switchports making up Port-Channel1.
HTH,
__
Edison.
Thanks very much for the quick reply
You mean to say that device should be connected to portchannle 1 or you want me to configure gi2/0/6 as port channel
Thanking you in anticipation
regds
Adhi
If you check the members of Port-Channel1 with the command show ether sum can you see if the port-channel is up?
Care to share the output here?
Did you configure teaming/etherchannel on a device connected to G2/0/6? What kind of device it is?
__
Edison.
hi
sh etherchannel s
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
1 Po1(SU) - Gi1/0/9(P) Gi2/0/9(P)
2 Po2(SU) - Gi1/0/1(P) Gi2/0/8(P)
Please help
regds
Adhi
Looks good, what's connected on 2/0/6, 1/0/9 and 2/0/9?
__
Edison.
hi
1/0/9 and 2/0/9 are port channeles connected COred DC
2/0/6 is trun link and again it is pointing to core DC
regds
Adhi
In addition to above all thse ports leads to one of DC (6500) catalyst switch.
However I did log onto Core-DC and see that there are some duplicate addresses referenced. If you look at the mac addresses these are associated with the MSFC routers. It would appear to me that there is some problem in the MSFCs. I'm not sure exactly what the issue is at this point. Although the logs are being overwritten I am assuming this has been happening for longer than just today.
Core-DC-1#sh ip int brief
Vlan1 172.16.1.50 YES NVRAM up up
Vlan2 172.19.19.50 YES NVRAM up up
Vlan10 172.17.10.2 YES manual up up
Vlan14 172.17.14.2 YES manual up up
Vlan16 172.17.16.2 YES manual up up
Vlan18 172.17.18.2 YES manual up up
Vlan38 172.17.38.2 YES manual up up
Vlan50 172.17.50.2 YES manual up up
Vlan51 172.17.51.2 YES manual up up
Vlan52 172.17.52.2 YES manual up up
Vlan53 172.17.53.2 YES manual up up
Vlan54 172.17.54.2 YES manual up up
Vlan68 10.68.1.2 YES manual up up
Vlan128 172.17.128.2 YES NVRAM up up
Vlan171 172.17.1.2 YES NVRAM up up
Vlan172 172.17.2.2 YES manual up up
Vlan200 10.201.1.37 YES manual up up
Vlan201 10.201.1.41 YES manual up up
Vlan202 10.201.1.45 YES manual up up
Core
Adhi
It seems those 3 ports were configured as etherchannel in Core DC and they need to be configured as etherchannel on the switch you are seeing the error.
__
Edison.
hI
cOULDNT GET THE ANSWER, COULD YOU PLEASE EXPALIN IT IN BRIEF
REGDS
KARTIK
4057
