05-03-2012 08:43 AM - edited 03-07-2019 06:29 AM
Hello. I just found out that one of our 10 3750's has been assigned with an IP Address that is in conflict with a PC that has been in production long before this 3750 was deployed in our environment. Good thing it is servicing devices on a separate vlan. The conflict IP Address is assigned to the default vlan of the switch so we can connect to it from the core.
If I change the IP Address of the switch, will it reboot and momentarily disconnect the devices connected to it?
Thanks in advance.
Solved! Go to Solution.
05-03-2012 08:50 AM
Carlos,
Changing the address of the switch won't cause a reboot. The problem you might see is if any of your clients is using the address as a default gateway. In that case, you could have several clients lose access to remote networks.
HTH,
John
05-03-2012 09:20 AM
Carlos,
Question: if there is a user from VLAN 975 that is accessing a VLAN 8 device connected to this switch, witll they be disconnected when I change the IP Address of the VLAN 975 of the switch?
They'll be disconnected if they're using it for their default gateway.
If I ping the switch's VLAN 975 IP Address, success rate is zero. Is this normal if there is an IP conflict?
Usually, no. What happens if you do a "show arp | inc
HTH,
John
05-03-2012 08:50 AM
Carlos,
HTH,
John
05-03-2012 09:03 AM
John,
Thank you. All the devices attached to this switch are on VLAN 8. The conflicted IP Address is on VLAN 975 (my apologies - I mentioned default VLAN). The core, where most of the users (and servers) are connected, may access VLAN 8 devices from VLAN 975 from a core port. Question: if there is a user from VLAN 975 that is accessing a VLAN 8 device connected to this switch, witll they be disconnected when I change the IP Address of the VLAN 975 of the switch?
Thanks again.
P.S. I am able to telnet to the switch using the VLAN 8 IP address of it. If I ping the switch's VLAN 975 IP Address, success rate is zero. Is this normal if there is an IP conflict? The switch will not even reply, even though I'm telneted to it via the other VLAN?
Again, thanks for your input.
05-03-2012 09:20 AM
Carlos,
HTH,
John
05-03-2012 09:36 AM
John,
When I do a "show arp", it gives me a list of all devices from Vlan8 under the "Interface" column, and one from Vlan975, which has mac address of the switch. The MAC address of the conflicting PC does not show on the arp table.
05-03-2012 12:29 PM
Note that when I do a "show ip route", the routing table is empty. And the person who configured this switch did not even set up a default gateway.
05-03-2012 12:38 PM
So, the switch is configured as L2? Can you do a "sh run int vlan975" and post that? Take addresses out if you need to. If it doesn't come back with anything at all, then the conflict isn't going to be with this switch if you don't have an address configured on it.
05-03-2012 02:07 PM
John, this is the detailed vlan975 interface info:
MY-3750#show run int vlan975
Building configuration...
Current configuration : 65 bytes
interface Vlan975
ip address 192.168.0.208 255.255.255.0
end
MY-3750#show interface vlan975
Vlan975 is up, line protocol is down
Hardware is EtherSVI, address is 0027.0ccd.0cc1 (bia 0027.0ccd.0cc1)
Internet address is 192.168.0.208/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input never, output 2y14w, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
31 packets output, 1984 bytes, 0 underruns
0 output errors, 0 interface resets
MY-3750#
05-03-2012 02:24 PM
Carlos,
It says that the line protocol is down. Do you have any hosts in that vlan at the moment? And can you do a "sh vlan"?
05-03-2012 02:59 PM
John,
There is no host in vlan 975 in this switch. Below is a snippet of the "sh vlan":
10 VLAN0010 active
11 VLAN0011 active
15 VLAN0015 active
16 VLAN0016 active
20 VLAN0020 active
30 VLAN0030 active
32 VLAN0032 active
33 VLAN0033 active
100 VLAN0100 active
975 VLAN0975 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
VLAN Name Status Ports
1005 trnet-default act/unsup
MY-3750#
05-03-2012 03:20 PM
Carlos,
If the vlan 975 is the problem address and no one is in that vlan, it's safe to change that ip anytime without worrying if someone will get disconnected. The line protocol is down which generally indicates no ports are associated with the vlan that are in the UP state.
05-03-2012 06:48 PM
Thank you. I'm changing it now from home.
Sent from my wifi-only iPhone.
05-03-2012 06:48 PM
05-03-2012 07:37 PM
I changed the IP Address of Int Vlan975 to 192.168.0.206 but status still shows "Vlan975 is up, line protocol is down". I still cannot telnet to the Vlan 975 of that switch. What am I missing?
05-04-2012 03:53 AM
Carlos,
If there's nothing in vlan975 that's connected and up, the switch won't show UP/UP. It's going to show Up/Down until a host that's assigned to the vlan that comes up. This is also the reason you can't ping the address when you're telnetted into vlan 8. I'm woondering if vlan 975 may have been used in the past, but since then someone has migrated all hosts to another vlan or was using this vlan as a test vlan. The vlan itself won't be active without a host in it. Here's an example:
Router#sh vlan-swit
1 default active Fa1/0, Fa1/1, Fa1/2, Fa1/3
Fa1/4, Fa1/5, Fa1/6, Fa1/7
Fa1/8, Fa1/9, Fa1/10, Fa1/11
Fa1/12, Fa1/13, Fa1/14, Fa1/15
975 VLAN0975 active
Router#sh int vlan 975
Hardware is EtherSVI, address is c418.7763.0000 (bia c418.7763.0000)
Internet address is 192.168.50.1/24
I have a router connected to f1/1, so I'll add that port to vlan 975:
Router(config-if)#switchport access vlan 975
Router(config-if)#
*Mar 1 00:01:51.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan975, changed state to up
Router(config-if)#do sh int vlan 975
Vlan975 is up, line protocol is up
Since you don't have any hosts on the vlan, it makes sense as to why you couldn't ping the address for vlan 975 while connected to the switch:
Router(config-if)#do ping 192.168.50.1
Sending 5, 100-byte ICMP Echos to 192.168.50.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Above I could ping while the host was in the vlan. Below I'll remove it, and notice that the line protocol goes back down:
Router(config-if)#no switchport access vlan 975
Router(config-if)#
*Mar 1 00:03:07.555: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan975, changed state to down
Now I can't ping the local address for vlan 975:
You have to have at least one member in the vlan up in order for the vlan itself to be up and functional.
HTH,
John
