05-19-2008 11:28 AM - edited 03-05-2019 11:05 PM
I have version 12.2(44)SE running on our 3750 switches...I wanted to upgrade to 12.4T, but in looking at the cisco download site under 12.4 and even 12.3, it doesn't list the 3750 switch. Are these switches not supported anymore??
Solved! Go to Solution.
05-19-2008 11:39 AM
12.4T is an IOS train for routers. Catalyst switches use a different numbering system and the 3750 runs 12.2(xx) at the moment.
Jon
05-19-2008 11:36 AM
Mike
The 3750 switches are certainly still supported. But the version numbers of the software are not what you are expecting. I just checked the software download site to verify, and the most recent code for the 3750 is 12.2(44)SE2.
Rick
05-19-2008 11:39 AM
Jon
05-19-2008 11:50 AM
gotcha...thanks!
