3750 Port Security Question?
Someone enabled port security on a 3750 switch that we need to disable. Is there a global configuration command that I can use instead of trying to disable it manually on 48 ports? any other recommendations will be appreciated.. Thanks,
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: 3750 Port Security Question?
Could you not just do
switch(conf t)# int range fa0/1 - 48
if gig ports gi0/1 - 48
switch(config-if-range)# no switchport port-security
Jon
Jon
Agree with Jon, just use " interface range" command and disable the port-security on all the interface :
conf t
interface range gig 1/0/1 - 48
HTH,
-amit singh
Awesome.. Thanks guys. 1 last thing to confirm. We have STP port fast enabled on that switch.. does removing port security cause problems with this or should I also disable Port Fast. Thanks for your help on this 3750.
Disabling port security shouldn't affect portfast or other configuration of the port.
Sundar
137
