01-09-2007 03:22 AM - edited 03-05-2019 01:40 PM
I'm in the process of setting up QoS and need to mark traffic with DCSP values, specifically Citrix traffic. The DSCP values will be used on the WAN QoS, marking needs to happen before the WAN router.
I've configured the following on the 3750:
Class Map match-all citrix-ica
Match access-group 100
Policy Map mark-citrix
Class citrix-ica
set dscp af31
access-list 100 permit ip any host 10.203.232.41 - Citrix server IP
Port on which Citrix server is connected:
service-policy input mark-citrix
Problem I have is that traffic is not being marked with the DSCP (checked using network monitor) - I've tried changing the access-list but to no avail. I'm sure the problem is with the access-list. Can anyone provide a config whereby traffic is marked based on Citrix i.e. ICA Port 1494
Thanks!
01-09-2007 03:30 AM
Hi Craig,
you are trying to mark traffic on the switch port the citrix server is connected to - right ?
If so - and as "service policy input" is used, in my understanding you have to switch source and destionation in access-list 100
access-list 100 permit ip host 10.203.232.41 any
Carsten
01-09-2007 04:12 AM
Yes I'm trying to mark switch port that the the Citrix server is connected to. As traffic enters the switch it's marked to DSCP AF31 therefore when it exits the switch then enters the WAN router QoS will be applied based on the DSCP marking.
Tried switching the access-list but doesn't seem to make a difference.
How would you check to see if the packets are indeed being marked?
01-09-2007 10:38 AM
Just to be shure - did you enable Qos on the switch via "mls qos" ?
You should be able to check if packets are marked via
"show mls qos interface gigabitethernet x/y/z statistics"
01-09-2007 10:55 AM
Yes, mls is enabled.
Will check the output from mls int fa1/0/16 stat (Citrix ethernet port)
01-09-2007 06:20 AM
Your created your Access-list and applied it to your class map. You then applied that class to the policy. You now need to apply your policy to your interface. Have you done this?? Please rate....
01-09-2007 07:59 AM
Yes, this was in the original message:
01-09-2007 12:40 PM
First you need to see if the access-list is being hit. Use the Show Access-list command to see if the address is being hit by the list. Next see if the policy is hitting the address. Use the Show policy command. This will show you if the policy that is applied to the interface is being hit....
02-25-2016 04:43 PM
Where did you decide to use DSCP value af31? I can't find any citrix documentation that suggests an ideal dscp value to mark with.
