3750 rate-limits
Hi!
My 3750 accepts the "rate-limit" command, but does not seem to be rate-limiting...is the rate-limit command supported in the 3750 series
Re: 3750 rate-limits
are you talking about 3750 router or Catalyst 3750? Which IOS version? Did you check the "unsupported commands" section of the configuration guide?
Usually the suitable command is "police" inside a policy-map.
Have a look at f.e. "Policing and Marking"
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00805a6504.html#wp1408392
If you have a router, then this should be helpful: "Policing and Shaping Overview"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080465b25.html
Hope this helps! Please use the rating system.
Regards, Martin
Thanks for your reply. This is helpful.
273
