3750 - Read-only CMS Access
Hi All,
I would appreciate some advice about a problem i am having - basically I am unable to access the configuration of the 3750 switch with read-only privilege via CMS by browsing to http://ip_address/level/5. I would appreciate any assistance. Many Thanks in advance... Yas Khan
Re: 3750 - Read-only CMS Access
AFAIK to access the config and all you need privilege level 15.
regds
Many thanks for a speedy response, however i resort to asking my question after trying the below as suggested by Cisco:
CMS provides two levels of access to the configuration options: read-write access and read-only access. If you know your privilege level, you must specify it in the URL that you use to access the cluster. For example, if your privilege level is 13, enter this URL:
http://ip_address/level/13/
As i've not been able to get the above working, i am obviously missing something somewhere!
All suggestions appreciated...
Thanks.
Are you facing problems in accessing the switch in whole or facing issues only in accessing the config ?
regds
Ok, let me explain - I can access the switch fine via CLI or CMS (with privilege level 15) however i need to configure read-only access to the switch config via CMS. I can do this for CLI access but its for a non-technical client who has requested gui access, but we want to give them read-only privileges. As per my previous post, Cisco suggest to browse to http://ip_address/level/1-14 to have read-only access, but I can't seem to get this working.
Thanks.
231
