05-22-2008 07:48 AM - edited 03-05-2019 11:10 PM
Is it possible to stack these two switches?
3750G - 24 port
3750 - 48 port
05-22-2008 07:56 AM
You should be able to do it. Please go through the link below for any cavetas.
-amit singh
05-22-2008 07:56 AM
Yes, if the IOS of the stack master is compatible with the hardware of any added slaves. Check out this white paper on StackWise and then search Cisco for the appropriate configuration guide(s).
05-22-2008 08:08 AM
No the models of switches have to be the same.
05-22-2008 08:11 AM
sorry i make a mistake
A Cisco 3750 switch can be stacked with any other model of Cisco 3750 switches. Catalyst 3750 switches that run Cisco IOS® Release 12.2(25)SEB are compatible with Cisco EtherSwitch service modules that run Cisco IOS Release 12.2(25)EZ. Catalyst 3750 switches and Cisco EtherSwitch service modules can be in the same switch stack. Within this switch stack, the Catalyst 3750 switch or the Cisco EtherSwitch service module can be the stack master.
