Webcast-Catalyst9k
3750 Stack consisting of different model switches
Is it possible to stack these two switches?
3750G - 24 port
3750 - 48 port
Re: 3750 Stack consisting of different model switches
You should be able to do it. Please go through the link below for any cavetas.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swstack.html#wp1189523
-amit singh
Yes, if the IOS of the stack master is compatible with the hardware of any added slaves. Check out this white paper on StackWise and then search Cisco for the appropriate configuration guide(s).
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_white_paper09186a00801b096a.html
No the models of switches have to be the same.
sorry i make a mistake
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml
A Cisco 3750 switch can be stacked with any other model of Cisco 3750 switches. Catalyst 3750 switches that run Cisco IOS® Release 12.2(25)SEB are compatible with Cisco EtherSwitch service modules that run Cisco IOS Release 12.2(25)EZ. Catalyst 3750 switches and Cisco EtherSwitch service modules can be in the same switch stack. Within this switch stack, the Catalyst 3750 switch or the Cisco EtherSwitch service module can be the stack master.
284
