3750 stack question...
If i remove a master switch in a stack, will the stack still work?
I just need to get this particular switch configs to upload to tftp without transferring the entire stack config over... how do i do that?
DUstin
Hall of Fame Super Silver
Re: 3750 stack question...
Hello Dustin,
I don't recommend to try what you suggest.
I would do the following:
use sh switch to locate the master in the stack to know its slot number
upload the whole config in a text file
with an editor remove the config of ports with slot different then the master's one
renumber to 1 the master slot number, if different, on the remaining interfaces
and you should have what you want without causing any change to the stack.
Hope to help
Giuseppe
Hey there!
So basically I just want to replace the 3750 to a 3750G, the switch is in that stack. If i do what you say, i shouldnt have no problem? The switch i am upgrading is the master, but its the only FastEthernet, So thats why i wanted to upgrade to a GIG switch.
I just get kinda nervous about this whole thing.
Hello Dustin,
depending on the IOS release there is a feauture called
Switch Provisioning for Stackwise technology
Allows switches in a 3750 stack to be pre-configured, prior to adding physically.
this should be the way to add the new switch to the stack.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swstack.html#wp1177470
Hope to help
Giuseppe
Giuseppe,
how do i get just that particular config from the one stack without getting all the others, so i can load onto the GIG switch. All the configurations will be the exact same, even though console, when i do a "show run", it shows the entire stack. I just need the configs from that particular stack so i can load onto a TFTP and load onto the new one...
any suggestions?
143
