3750 Stack Switch Addition
All,
I added a switch to a stack this weekend. This is the 6th switch, but it's physically located above the 1st switch in the rack. I'd like to renumber these. I know that I can do "switch 6 renumber 1", but I don't think that will work as long as 1 exists when the newly renumbered 6 comes online. Do I need to shut down the stack completely, bring up all of the switches one by one and renumber? What's the best way to go about doing this?
In the end, what I'll need is this:
Switch:
6 renumbered to 1
1 renumbered to 2
2 " to 3
3 " to 4
4 " to 5
5 " to 6
I'd also like to know if this will negatively impact me in anyway with existing VLANs, trunked ports, etc.
John
HTH, John *** Please rate all useful posts ***
Re: 3750 Stack Switch Addition
You can probably follow this order:
Renumber 5 to 7
Renumber 4 to 5
Renumber 3 to 4
Renumber 2 to 3
Renumber 1 to 2
Renumber 6 to 1
Renumber 7 to 6
Hall of Fame Super Bronze
Recommended approach.
How about placing the 6th switch in the 6th slot ? :)
Vlans are stored in the Vlan.dat which is shared among all switches. No need to be concerned about that.
Trunked ports are configured on the switchports, unless you are moving those connections around, you should be fine.
For instance, if switch 1 is connecting back to the core and now you have a different switch 1, then you need to modify those settings. Also, any reference to a switchport will need to modify its numbering.
HTH,
__
Edison.
Thanks Edison. The reason for not putting the switch below the 5th switch is because we've run out of room in the rack. It was easier to install the 6th switch above 1, rather than move all 5 up the rack to get the 6th in the bottom. :-)
John
Gold
1) the stack number is not something that is important for other things than you to remember wich one is wich one.
and the configuration to remember wich one is wich one.
however if you need too have them in a specific order you need to do it in this way.
renumber 5 to 7
renumber 4 to 5
renumber 3 to 4
renumber 2 to 3
renumber 1 to 2
renumber 6 to 1
renumber 7 to 6
IF you are going to do this make shure you do not have anything in the configuration with interfaces. then that will be wrong and you have to change the configuration.
ie int gig1/0/1 after the change becomes int gig2/0/1.
good luck
747
