3750 stack switch - showing switch 2 ports also
Hi All  ,
I have 3750 stack switch which was part of stacking in the past.
We want to use it as standalone switch at one of the site .
When I checked the show ip int brief output , I am getting switch 2 interfaces also , which is not stacked with Switch 1.
To remove switch 2 ports from the the configuration , I have erased the startup configuration and rebooted the Switch 1 but no luck..Still getting / seeing  switch 2 ports in the "show ip int bri" and "show run" output.
Is there any way to have only switch 1 ports on the switch 1 as switch 2 is not stacked with switch 1.
After executing erase startup , why switch 2 ports are not going off from switch 1.
Thanks ,
M S K
Thanks , M S K
VIP Purple
Re: 3750 stack switch - showing switch 2 ports also
You have to remove the member from the stack:
no switch X provision
where X is the number of the switch to remove (2 in your case).
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
VIP Super Bronze
Try this:
Login to the switch and rename it to switch-1 and then reboot it.
103
