rohit.baweja wrote:
Hi Tech Gurus,
Just want to know that new 3750-X series is compatible with old 3750 series or not??? if yes, then what is the requirements like to change the IOS Image or not???
Wating for the reply
Thanks in advance!!!
Yes, as long as you are not running the new LAN Base image on the 3750-X, see this Q&A for more details, the bit just below Table 2 covers compatibility issues -
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/qa_c67-578933.html
Jon
