Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
3750 StackWise cables hot swappable?
I have a stack of 3750's that have their StackWise cables in the wrong order. Do I need to power off the switches to rearrange the StackWise cables?
Thanks in advance!
Re: 3750 StackWise cables hot swappable?
Hi Friend,
It is always suggested to remove the switches that you want to disconnect from the stack. Taking the stackiwise cable out from the switch stack can result a single stack to be divided into two and can result in different problems.
I would suggest to power off the stack and then power on the Stack master first and then rest of the switches.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225sed/scg/swstack.htm#wp1156338
HTH, Please rate if it does.
-amit singh
Thank you so much for the fast response!
3467
