3750 switch stack with 10 linksys roouters
Hello as a temp solution can I use 10 linksys routers with dhcp scopes patched to a 3750? Or can I use a 3750 as the dhcp server? Do I have change my ios for it to dhcp serve?
1 REPLY
Hall of Fame Super Silver
Re: 3750 switch stack with 10 linksys roouters
Hello David,
you should be able to define 10 DHCP pools locally on the C3750.
you shouldn't need an IOS upgrade.
if you post sh ver | inc image
from C3750
or you can check by yourself using
Feature Navigator
www.cisco.com/go/fn
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swdhcp82.html#wp1320911
you can even enforce ip address assigned on a per port basis
Hope to help
Giuseppe
136
