Community Member
3750
Which model of 3750 switch can contain 24 Fibre connections and 2 10/100baseT connections?
thanks
Community Member
Re: 3750
Cisco Catalyst 3750G-12S Switch
http://www.cisco.com/en/US/products/hw/switches/ps5023/ps5469/index.html
-SA
Community Member
Re: 3750
Thanks for that;
Correct me if I'm wrong, but isn't the 3750G a 12 port switch with no 10/100baseT capability?
thanks
Community Member
Re: 3750
That is correct it does not have 10/100 port.
-SA
Community Member
Re: 3750
Am I correct in saying that it only has 12 fibre connections? Is there a 3750 that allows 24 fibre connections?
thanks
Silver
Re: 3750
No, but there is a 3560 with 12 TenGigE ports. With the switch you can buy TwinGigE converter (if you buy it with the switch - all 12 of the are for free!), and buy 24x Optical SFP modules.
Here is your option:
1. 3560E-12D http://www.cisco.com/en/US/products/ps7078/prod_models_comparison.html
2. 12x Converters for free: http://cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/product_data_sheet0900aecd805bbee3.html
3. 24x SFP modules for your optical connections:
http://cisco.com/en/US/prod/collateral/modules/ps5455/ps6577/product_data_sheet0900aecd8033f885.html
Hope this helps
Community Member
Re: 3750
No 3750s have that. You'll need to get a 4500 or 6500 series switch. They have various line cards that can support that requirement.
Community Member
Re: 3750
Robert,
Not very big on design, but is it possible to get any 24 port gigabit ethernet switch and plug in 24 sfp's. Or is there some restriction on this?
thanks
166
