04-23-2012 02:16 PM - edited 03-07-2019 06:17 AM
Hi, Qos question.
We tested a QoS in a Cisco 3750E, IOS: 12.2(58)SE2.
Voice traffice in the correct Q without any problem, but all the others traffic the Defualt Q (0), tried to capture the traffic and tcp/udp port are correct.
Any thing wrong with my ACL or DSCP - CoS?? ( that ACL works fin on 4500 and 6500)
Thanks ahead.
LAB-C3750e-24pd#show mls qos int g1/0/1 statistics
GigabitEthernet1/0/1 (All statistics are in packets)
dscp: incoming
0 - 4 : 135997 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 18
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 1313 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 68438 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 0 0 220 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 137335 0 0 0 0
5 - 7 : 0 0 0
cos: outgoing
0 - 4 : 68789 0 0 0 0
5 - 7 : 0 220 80
output queues enqueued:
queue: threshold1 threshold2 threshold3
queue 0: 0 0 0
LAB-C3750e-24pd#show mls qos maps dscp-cos
Dscp-cos map:
d1 : d2 0 1 2 3 4 5 6 7 8 9
0 : 00 00 00 00 00 00 00 00 01 01
1 : 01 01 01 01 01 01 02 02 02 02
2 : 02 02 02 02 03 03 03 03 03 03
3 : 03 03 04 04 04 04 04 04 04 04
4 : 05 05 05 05 05 05 05 05 06 06
5 : 06 06 06 06 06 06 07 07 07 07
6 : 07 07 07 07
LAB-C3750e-24pd#show mls qos maps cos-dscp
Cos-dscp map:
cos: 0 1 2 3 4 5 6 7
dscp: 0 8 16 24 32 46 48 56
Here is the config:
interface GigabitEthernet1/0/1
switchport access vlan 874
switchport mode access
srr-queue bandwidth share 5 30 40 10
srr-queue bandwidth shape 0 0 0 0
queue-set 2
priority-queue out
service-policy input QOSMARK
mls qos map cos-dscp 0 8 16 26 32 46 48 56
class-map match-any VoIP
description Voice IP Phone RTP
match access-group 157
(deleted)
class-map match-any Others
description Generic TCP, TFTP
match access-group 151
policy-map QOSMARK
class VoIP
set dscp ef
(deleted)
class Others
set dscp cs1
class class-default
set dscp default
access-list 151 remark * Others class (IP Precedence 1)
access-list 151 remark * Bulk NFS and File transfer
access-list 151 permit tcp any any eq 445
access-list 151 permit tcp any eq 445 any
access-list 151 permit tcp any eq 139 any
access-list 151 permit tcp any any eq 139
access-list 151 permit tcp any eq 2049 any
access-list 151 permit tcp any any eq 2049
access-list 151 permit UDP any eq 2049 any
access-list 151 permit UDP any any eq 2049
access-list 151 permit tcp any eq 8447 any
access-list 151 permit tcp any any eq 8447
access-list 151 remark - TFTP traffic
access-list 151 permit udp any any eq tftp
access-list 151 permit udp any eq tftp any
access-list 151 remark ***
access-list 151 remark ****
access-list 157 remark * VoIP class (IP Precedence 5)
access-list 157 remark - voice RTP packets
access-list 157 permit udp any any range 16384 32767
access-list 157 permit udp any range 16384 32767 any
access-list 157 remark ***
access-list 157 remark ****
04-23-2012 03:33 PM
You won't see the counters incrementing as the QoS tag is applied on ingress.
In order to verify if the QoS tag is applied correctly, you need to verify the counters in the egress port from this switch.
The order of operations is the counters are done before the QoS tag is applied.
BTW, you should modify the cos-to-dscp mapping by following this document:
Table 2-3
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoSDesign.html#wp999437
04-24-2012 06:09 AM
to verify the counters in the egress port - you mean L3 interface? that uplink ports on both side set with mls qos trust dscp.
any command for that (show policy-map interface or others )
Sorry, I am still new in the QoS field.
04-24-2012 05:56 PM
The interface being used as the egress for these packets, being L2 or L3.
The point I'm trying to make is that you won't see counters for packets being tagged while entering the switch.
You will see the counters if the packet has the QoS marking from the end device while entering the switch.
If the switch is tagging the packet at ingress, you will see the marking counters at the egress port.
