3750G-12S
Is 3750G-12S-SD switch supports OSPF and PVRST+
Hall of Fame Super Gold
Re: 3750G-12S
OSPF is supported with the IP Services feature set.
Re: 3750G-12S
OSPF and other routing protocols are supported in IPBASE series IOS image.
Hope to help !!
Ganesh.H
Re: 3750G-12S
IP base supports only RIP & Static .. If you need OSPF, you need to have IPServices enabled. Please have a look at Q&A of 3750:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_qas09186a00801b0971.html
Raj
Re: 3750G-12S
and were you referring to RPVST on your post ? If so, Rapid PVST is supported on IPBASE image. You would not need IP Services
to enable Rapid PVST...
Attaching a file which has all features enabled on IPBASE software. This is for c3750-ipbasek9-mz.12.2-25.SEE4
Raj
232
