3750G configuration stack commands
CCDEdeity
Using a current 2950, and replacing with a 3750G POE-with an additional 3950G as a back-up (stack) is there a configuration sheet that will give me a step-by-step CLI so I can configure the new switch with my current 2950 configuration?
5 Replies 5
Giuseppe Larosa
Hello Leroy,
I would first configure the stack of the two new C3750s.
Actually, the ports will be seen as 1/0/x and as 2/0/y after you have the stack running.
After having done this, the configuration of the single port can be copied to the right port(s).
port 0/x on c2950 becomes 1/0/x and 2/0/x on the c3750 stack if you want to have a backup switch.
if the second C3750 is for backup I wonder if the stack is useful.
Hope to help
Giuseppe
If I the 3750 config works I will let everyone know the details less headaches for everyone else
Davy Ad
Hi Leroy,
Hi i think it will be better if the other switch is 3750 as well .Here is the link
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swstack.html
Hey Dave,
Thanks for your help-this may get me rolling in the right direction.
Roy
don't forget to rate
DAk
