10-06-2014 04:38 PM - edited 03-07-2019 09:00 PM
First off, I know there was another topic somewhere in the discussion boards about 3750 high CPU utilzation which I've referenced. Just looking for some feed back on my scenario here.
We're experiencing some intermittent network issues and I'm starting to think it's stemming from our core 3750 stack. I have (2) WS-C3750G-48PS switches stacked. They are SW Image C3750-IPSERVICESk9-M and running 12.2(58)SE2.
When we experience network "slowness" I've noticed CPU spikes on the switch stack. I don't know what tends to be average vs. unhealthy. I've pasted the output for "show proc cpu history" even though it doesn't paste in too well, you can kind of get the picture.
Core-1-3750Stack#sh processes cpu history
222222111113333333333444445555544444222221111111111111111111
144444777777777766666444441111100000888887777777777999998888
100
90
80
70
60
50 *****
40 *************************
30 ******************************
20 **********************************************************
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
552355455625555656688898999899999899899986687566855656565467
115495777085367281159907011601221901812068456710343090429201
100
90 *##**##***#####*#*#*#* *
80 *################*###* ** *
70 ######################* ** *
60 ** *** * **#***#######################*#***#* *** **
50 ** *#*#** ****##########################################
40 ** ###### #*############################################*
30 ##*#######*###############################################
20 ##########################################################
10 ##########################################################
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
999999998977676986766867666677687666667976676767666666766767666966667999
991222220032875014986366444523273857631109937787879745047739986154952012
100 **
90 ******** * * * * * *
80 ********** * ** * * * * * * * * * * *
70 ***************** ****** *** ****** ************** ** ** ****** ****
60 ******#***************************************************************
50 #*****#***************************************************************
40 ##*#*##***************************************************************
30 ########*************************************************************#
20 ######################################################################
10 ######################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
Additionally, here is cpu process sorted:
CofR-Core-1-3750Stack#show processes cpu sorted
CPU utilization for five seconds: 57%/29%; one minute: 47%; five minutes: 43%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
161 108718387 107210878 1014 10.32% 9.09% 7.80% 0 Hulc LED Process
102 34027334 357495 95184 5.08% 1.07% 0.89% 0 HULC Tcam Memory
96 52608505 102581449 512 2.31% 2.39% 2.19% 0 HLFM address lea
82 48842354 183628533 265 1.23% 1.35% 1.34% 0 Fifo Error Detec
121 40852019 7533520 5422 0.92% 1.15% 1.09% 0 hpm counter proc
76 22245248 98530442 225 0.46% 0.46% 0.49% 0 RedEarth Tx Mana
238 26135643 40775562 640 0.46% 0.70% 0.78% 0 Spanning Tree
171 14668729 715024 20515 0.30% 0.38% 0.38% 0 HQM Stack Proces
305 1276077 112200200 11 0.30% 0.05% 0.01% 0 MMON MENG
224 7786230 14162648 549 0.30% 0.44% 0.36% 0 IP Input
172 5682987 2842030 1999 0.15% 0.16% 0.16% 0 HRPC qos request
Does any of this out of the ordinary? I want to make sure my core switch isn't going to die on me anytime soon :)
Thank you!
10-06-2014 05:32 PM
Use 12.2(55)SE9.
10-07-2014 08:08 AM
Thanks. I think I'll give 12.2(55)SE9 a try. Appears to be the recommended version.
10-06-2014 08:02 PM
Few links to ts the high cpu:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/cpu_util.html
Inayath
10-06-2014 08:04 PM
also I have created the document for the same;
https://supportforums.cisco.com/document/12298401/troubleshooting-high-cpu-3750
10-07-2014 09:00 AM
dear eric-owens,
Your high cpu is because of interrupt traffic. As per my experience, myself first check whether any end systems are generating any high multicast/broadcast. You may please check all access port input traffic ( show interface | include input traffic ) size, you may get one system will keep broadcasting/multicasting the traffic which may be around 3 to 5 Mb constantly.
Jubair.S
10-07-2014 09:34 AM
Thanks for the suggestion Jubair. I may not be following you're suggestion or maybe this isn't the issue, but when I do a (show interface | inc input traffic) I don't see any results.
I'm not sure where to look for specifically for any interrupt traffic. Maybe it's a good thing if I don't see the output? I'm not sure.
Core-1-3750Stack#show interfaces | inc input traffic
Core-1-3750Stack#
Thanks.
10-07-2014 01:49 PM
Dear eric-owens,
apologies, it is show interface | inc input rate, kindly check what are the highly utilized interfaces and trace it.
Jubair.S
