3750G not wanting to route vlan's
Ok I have a 3750G stack setup with ip routing.  I can ping all the gateways from the 192.168.1.0/24 network and get IP's from DHCP.  But I can't ping past the gateways and if I connect a machine to those vlan's it will not get an address from DHCP if I plug in a address manually I can ping it's gateway but no farther. I have attaced the config file and the sh ip route command output.  Any help would be great! Thanks.
Everyone's tags (1)
1 REPLY
Purple
For DHCP, verify that the DHCP server has a route back to the scope it will deliver as it must reach the IP address where the IP helper is configured.
Can you ping the VLAN intefaces from a host in another VLAN ? if so intervlan is functioning
Has the default-gateway a route back to the VLAN subnets ?
Alain
117
