Webcast-Catalyst9k
3750G Software upgrade standard-->Enhanced
Facing a problem upgrading the IOS for 3750G standard image to Enhanced Image.
show ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICES-M), Version 12.2(25)SEB4, R
ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 15:47 by yenanh
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE3, RELEASE SOFTWA
RE (fc1)
aedxbmort01 uptime is 2 minutes
System image file is "flash:/c3750-ipservices-mz.122-25.SEB4/c3750-ipservices-mz
.122-25.SEB4.bin"
cisco WS-C3750G-24TS (PowerPC405) processor (revision P0) with 118784K/12280K by
tes of memory.
Processor board ID FDO1125Z7GP
Last reset from power-on
6 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1C:58:5A:55:80
Motherboard assembly number : 73-7058-14
Power supply part number : 341-0045-01
Motherboard serial number : FDO112507RE
Power supply serial number : PHI1044L0K8
Model revision number : P0
Motherboard revision number : A0
Model number : WS-C3750G-24TS-S need to be WS-C3750G-24TS-E
System serial number : FDO1125Z7GP
Top Assembly Part Number : 800-21894-07
Top Assembly Revision Number : A0
Version ID : V07
CLEI Code Number : COM7800ARA
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 WS-C3750G-24TS 12.2(25)SEB4 C3750-IPSERVICES-M
Configuration register is 0xF
what might be the problem??
Purple
Re: 3750G Software upgrade standard-->Enhanced
Can you point out what the problem is ? I don't see any issue. It loaded the ip services image. A blurb from the cisco upgrade doc.
Note For Catalyst 3750 and 3560 switches and the Cisco EtherSwitch service modules, although the show version output always shows the software image running on the switch, the model name shown at the end of this display is the factory configuration (IP base image [formerly known as the SMI] or IP services image [formerly known as the EMI]) and does not change if you upgrade the software image.
see the is problem is that i just wanted to know wanted is this image standard or enhances once
if it is can EMI image it should change to E instated of S
so please clarify wht is image is Standard or Enhance..
If you can run OSPF then it's the enhanced image - if not it's the standard.
Unless things have changed recently that's how I tell. It will also say on the back of the unit.
649
