I have a Cisco 3750g which has a faulty console port.
My model is the ws-3750g-24t-s, it has 24 gigabit ethernet ports, two stack ports and the serial console. It has no additional ports (so no usb) and no removable flash.
I cannot get any output at all from the serial console, nothing is printed during boot, not even the garbage produced by an incorrect baudrate. I suspect this is a hardware problem, which I cannot fix.
Besides the console, the rest of the switch works correctly, and I have been using it as a slave in a stack configuration without problems.
I now need it to operate on its own, without being attached to a stack master. The question is.. how do I do this?
- Somehow, I need to configure one of the ethernet ports to bring up an ip address and open an ssh server, so I can configure the swich.
- Is there a default ip configuration I can use to connect to an unconfigured switch without using the serial console?
- Maybe I can set it as a stack member to access the flash from the master, and copy a configuration into it?
