03-19-2015 10:17 AM - edited 03-07-2019 11:10 PM
I'm upgrading a stacked 3750X - one and 3750X-24TS and the other a 3750X-48TS. I have downloaded the IOS files that correspond which each switch from the software download page (15.0.(2)SE7). The question I have is this: Are the two files exactly the same? They are the same size, but...
I don't have room to install both as separate, but won't have to worry about that if the files are the same for a 24TS as it is for a 48TS.
03-25-2015 06:49 PM
03-25-2015 11:24 PM
Thanks Dan. Discussion moved to correct forum.
03-26-2015 10:30 AM
thank you for the feedback Dan....now I know.
03-26-2015 09:37 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Although Cisco's IOS image page lists all known models, often they all run the same physical image.
Besides being the same file size, are the files also named alike? Have you run a file comparison utility against them?
03-26-2015 10:29 AM
Thanks Joseph. Yes, they are the same file name and no, I have not run a file comparison.
03-26-2015 12:11 PM
Disclaimer
Posting
BTW, running a file comparison is "overkill", but then you would know/prove the two files are identical.
Community Feedback Forum is dedicated to "Tell us your opinions, suggestions, concerns, and feedback on the new Cisco Support Community". You are off-topic here, don't expect a valuable response. Please delete the thread here (big red button on top) and recreate it in proper community according specific Cisco technology or solution in question. Consider LAN, Switching and Routing ...
Thank you.
