10-10-2014 02:49 PM - edited 03-07-2019 09:04 PM
I already have a 3750x configured and in place at a location. I have a new 3750x switch I just got in and will be connecting it with a data cable to create a stack. My question is, do I have to configure the second switch at all or will it get all of it's configuration information from the first switch?
10-10-2014 03:31 PM
As long as the second switch has the same exact IOS and license as the first one, you don't need to configure it separately. Whatever you configure on the master will be pushed to the member.
Also to stack the switches together you need a stacking cable not regular data cable.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swstack.html#pgfId-1177470
10-14-2014 09:02 AM
Hi oscarwinski,
This is in addition what Reza has advised.
If you happened to power down the master switch, please make sure that you power up the master switch (existing switch) first and let the master switch boot up completely before you power the second switch (i.e. new switch).
If you did other way around, your new switch will be the master and all previous configuration from old-master switch will be deleted from running-configuration (assuming they are connected via stack-cable).
Rizwan Rafeek.
