3800 VPN Module
I have the following module on my router.
Cisco 3845 (revision 1.0) with 221184K/40960K bytes of memory
6 FastEthernet interfaces
2 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
How do I know if the VPN module is VPN acceleration module or VPN encryption module...
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: 3800 VPN Module
Let's see the show diag output.
__
Edison.
Re: 3800 VPN Module
Sh diag output as follows :-
Slot 0:
C3845 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapter, 10 ports
Port adapter is analyzed
Port adapter insertion time unknown
Onboard VPN : FW ver01100200
EEPROM contents at hardware discovery:
Hardware Revision : 1.3
Top Assy. Part Number : 800-23616-05
Board Revision : A0
Deviation Number : 0
Fab Version : 05
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 69
CLEI Code : IPME110BRA
Product (FRU) Number : CISCO3845-MB
Version Identifier : V05
Chassis MAC Address : 0018.185b.3450
MAC Address block size : 48
Part Number : 73-8799-08
Hardware date code : 20060525
Chassis Serial Number : 2770QE
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 30 32 31 36 55 30 45 40
0x10: 04 2C 41 01 03 C0 46 03 20 00 5C 40 05 42 41 30
0x20: 88 00 00 00 00 02 05 03 00 81 00 00 00 00 04 00
0x30: 09 69 C6 8A 49 50 4D 45 31 31 30 42 52 41 CB 8C
0x40: 43 49 53 43 4F 33 38 34 35 2D 4D 42 89 56 30 35
0x50: 20 D9 02 40 C1 C3 06 00 18 18 5B 34 50 43 00 30
0x60: 82 49 22 5F 08 83 01 32 19 6D C2 8B 46 43 5A 31
0x70: 30 32 37 37 30 51 45 FF FF FF FF FF FF FF FF FF
Re: 3800 VPN Module
According to the product's page, OnBoard VPN Encryption:
http://www.cisco.com/en/US/products/ps5856/index.html
HTH,
__
Edison.
Re: 3800 VPN Module
thansk
what is "AIM-VPN Module"
Re: 3800 VPN Module
Is there a way to check current cpu & memory utilization on 3840 router..
can I get history of cpu and memory utilization of 3840 router...
Re: 3800 VPN Module
970
