11-26-2008 08:36 AM - edited 03-06-2019 02:41 AM
Hello folk, I have a 3825 and I wanted to add an NM-2FE-2W network module. I'm not sure if this is support by the router. Kindly let me know If this is possible.
Solved! Go to Solution.
11-26-2008 08:46 AM
In the datasheet for the 3800 series it shows the NM-2FE2W-V2 as a supported card.
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8016a8e8.html
Hope that helps.
11-26-2008 08:52 AM
Yes, its supported.
NM-2FE2W*
2-port 10/100 Ethernet 2-WIC-slot network module
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_qas0900aecd8016a953.html
Arul
*Pls rate if it helps*
11-26-2008 08:46 AM
Hope that helps.
12-08-2008 05:53 AM
Thanks for your help sorry it took me a while to rate/respond to your answer.
11-26-2008 08:52 AM
Yes, its supported.
NM-2FE2W*
Arul
12-08-2008 05:54 AM
Arul,
Thanks for your help on this, sorry it took me a while to respond.
