3845 route
bma
Which IOS version is better for Cisco 3845 route for BGP and HSRP?
ben
hoogen_82
Level 4
Level 4
Post your show version from your router.
-Hoogen
royalblues
Level 10
Level 10
You would require either advance Ip services, enterprise services or SP services feature set in the IOS for BGP support.
BGP support was included even in the advance security feature set begining from 12.4
HSRP is supported in almost all releases.
You should try to use the latest IOS image as it has more bug fixes.
12.4.13b is the latest available on CCO for 3845 routers
HTH, rate if it does
Narayan
Totally agree on Narayan suggestion.
And always use "Cisco Feature Navigator":
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH,
Mohammed Mahmoud.
Thanks all.
We will use 3845 route replace old route in the new location.
ben
