11-11-2014 01:16 AM - edited 03-07-2019 09:27 PM
Dear Cisco-Community,
I have a question regarding egress queueing on a 3650 switch, Cisco IOS XE Release 3.3.3SE.
Ingress queuing works fine for phones (packets run into right classes), but when i look at the egress ports (uplink to core switch), the traffic does not appear to run into the right classes. whats is wrong or do i have a misunderstanding of the concept?
Config attached.
Thank you!
Uplink1:
#show policy-map interface GigabitEthernet1/1/1
Service-policy output: egress_qos_marking
queue stats for all priority classes:
Queueing
priority level 1
(total drops) 0
(bytes output) 45919
Class-map: voice_payload_egress (match-any) //NO MATCHES HERE. WHERE ARE MY EF VOICE PACKETS??
0 packets
Match: dscp ef (46)
0 packets, 0 bytes
5 minute rate 0 bps
Match: cos 5
0 packets, 0 bytes
5 minute rate 0 bps
Match: precedence 5
0 packets, 0 bytes
5 minute rate 0 bps
Priority: Strict,
Priority Level: 1
police:
rate 10 %
rate 100000000 bps, burst 3125000 bytes
conformed 0 bytes; actions:
transmit
exceeded 0 bytes; actions:
drop
conformed 0 bps, exceeded 0 bps
Class-map: voice_control_egress (match-any)
0 packets
Match: dscp cs3 (24)
0 packets, 0 bytes
5 minute rate 0 bps
Match: cos 3
0 packets, 0 bytes
5 minute rate 0 bps
Match: precedence 3
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
(total drops) 0
(bytes output) 0
bandwidth remaining 10%
queue-buffers ratio 35
Class-map: scavenger_egress (match-any)
0 packets
Match: cos 1
0 packets, 0 bytes
5 minute rate 0 bps
Match: precedence 1
0 packets, 0 bytes
5 minute rate 0 bps
Match: dscp cs1 (8)
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
(total drops) 0
(bytes output) 0
bandwidth remaining 20%
queue-buffers ratio 5
Class-map: class-default (match-any)
186703 packets
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
(total drops) 0
(bytes output) 22937020
bandwidth remaining 60%
queue-buffers ratio 45
Uplink2:
GigabitEthernet1/1/2
Queueing
priority level 1
(total drops) 0
(bytes output) 1988045
0 packets
Match: dscp ef (46)
0 packets, 0 bytes
5 minute rate 0 bps
Match: cos 5
0 packets, 0 bytes
5 minute rate 0 bps
Match: precedence 5
0 packets, 0 bytes
5 minute rate 0 bps
Priority: Strict,
Priority Level: 1
police:
rate 10 %
transmit
drop
0 packets
0 packets, 0 bytes
5 minute rate 0 bps
Match: cos 3
0 packets, 0 bytes
5 minute rate 0 bps
Match: precedence 3
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
(total drops) 0
(bytes output) 0
0 packets
Match: cos 1
0 packets, 0 bytes
5 minute rate 0 bps
Match: precedence 1
0 packets, 0 bytes
5 minute rate 0 bps
Match: dscp cs1 (8)
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
(total drops) 0
(bytes output) 0
200341 packets
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
(total drops) 0
(bytes output) 23138397
Client Port:
show policy-map interface Gi1/0/1
GigabitEthernet1/0/1
Service-policy input: edge_qos_marking
Class-map: voice_payload (match-any) //HERE OKAY
14166 packets
Match: access-group name acl_voice_payload
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set
dscp ef
Class-map: voice_control (match-any)
77 packets
Match: access-group name acl_voice_control
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set
dscp cs3
80723 packets
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
QoS Set
dscp default
01-06-2015 08:01 PM
https://supportforums.cisco.com/discussion/10863531/acl-qos
