3850 48 ports 10/100/1000 + 12 ports 1gb/10gb
Hi!
I need to know if the model ws-c3850-12x48u-s has 48 ports 10/100/1000 or only 36 are 10/100/1000 and the 12 are 1gb/10gb.
In some cisco specs i saw both descriptions.
Example:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/data_sheet_c78-720918.html
and
http://www.cisco.com/c/en/us/products/switches/catalyst-3850-series-switches/models-comparison.html
I only need 2 ports 1GB/10GB, the others has to be 10/100/1000.
Someone knows witch spec is the right one??
Thx!
1 REPLY
Hall of Fame Super Gold
Copper or SFP?
PoE or non-PoE.  mGIG or non-mGIG?
WS-C3850-12X48U means the following:
1.  48 ports 10/100/1000BaseTx;
2.  All ports are PoE/PoE+/uPoE;
3.  Of the total 48 ports, 12 of the ports (the ones with the blue bar on the bottom) support mGIG (aka 802.3bz)
If you need an SFP/SFP+ ports capable of supporting one 1 Gbps and one 10 Gbps, then you'll need to order the C3850-NM-2-10G module (SFP/SFP+ modules not included).
77
