3850 qos question
i ve done some qos configuring on the 3850 switch. The Q is What am i doing wrong?
It seems that traffic from my laptop is being put in the high prio queue, or i made a mistake. (I ve checked wireshark, my laptop traffic: dscp 0x00. There is no ip phone connected to the port.
here is a little test config, i want to check here if cos 0 is being put in the low prio queue (priority level 2)  but i only see traffic output in the high prio queue?
I m sure the laptop is sending packets with dscp 0x00
class-map match-any CM_ANY
match dscp default
match cos 0
class-map match-any CM_VOIP
match dscp ef
match cos 5
policy-map TEST
class CM_VOIP
priority level 1 percent 5
class CM_ANY
priority level 2 percent 5
interface GigabitEthernet1/0/1
switchport access vlan 10
switchport mode access
switchport voice vlan 20
trust device cisco-phone
spanning-tree portfast
service-policy output TEST
sh policy-map interface GigabitEthernet 1/0/1
Service-policy output: TEST
queue stats for all priority classes:
Queueing
priority level 1
(total drops) 0
(bytes output) 1191
Queueing
priority level 2
(total drops) 0
(bytes output) 0
Class-map: CM_VOIP (match-any)
Match: dscp ef (46)
Match: cos 5
Priority: 5% (500 kbps), burst bytes 12500,
Priority Level: 1
Class-map: CM_ANY (match-any)
Match: dscp default (0)
Match: cos 0
Priority Level: 2
Class-map: class-default (match-any)
Match: any
(total drops) 0
(bytes output) 0
1 ACCEPTED SOLUTION
Purple
3850 qos question
traffic from pc and phone is entering this port not exiting and an output policy is for packets exiting a port not entering.
Alain
Purple
3850 qos question
Alain
3850 qos question
Hi Alain
ok, ofcourse that makes sense ;-)
I was wondering why all output traffic ends up in prio queue 1.
So what i m seeing in the output of prio queue 1 must be traffic from the switch towards the port the laptop is connected to.
Like stp. I ll do some tests to put that traffic in a different queue since i only want voip in prio queue 1.
Thanks!
VIP Purple
3850 qos question
What is your test topology ? Is it single 3850 switch or any other switches ? we understand you connect a laptop to G1/0/1 & you configure QoS on that port ? Traffic comming out of that port, from where it is coming ?
Pls provide more info to see why you get all traffic in high priority queue
Rasika
3850 qos question
Hi, Rasika
thanks for your reply.
Correct, 1 switch and 1 laptop connected to Gi 1/0/1.
I think it must be management traffic coming from the switch going towards the laptop.
i ll do some tests with some class-maps to try and match it and send it to another queue and check wireshark to see what traffic it is. .
VIP Purple
3850 qos question
Connect another PC on to different swichport & check what happens when you communicating with each other. Most of the time in practical scenario, a packet traverse across more than 1 switch. So if you can set up two switches via a trunk link and two end points connect to two differnt switches, that will give you better understanding how each port needs to be configured for QoS
Let us know how you goes with this
Rasika
345
