Community Member
3850 Stack continuous message
I got this message on my stack and i don't know what it means:
10-02-2013    16:10:04    Local0.Emerg    182.9.200.70    67854: 085266: Oct  2 16:11:06 GMT: %IOSXE-0-PLATFORM: 1 process wcm: *apfReceiveTask: %AVL-0-TREE_FULL_ENTRY_DOES_NOT_EXIST: AVL tree 0x12c76268 is full. Entry is not present in AVL tree.
10-02-2013    16:10:05    Local0.Error    182.9.200.70    67855: 085267: Oct  2 16:11:06 GMT: %IOSXE-3-PLATFORM: 1 process wcm: *apfReceiveTask: %APF-3-MOBILE_SEARCH_ENTRY_CREATE_FAIL: Could not add client  145A.057C.5B1C  AuditSessionID: b609c846524c458e0000244e w/ IP 192.168.9.217: list is full.
10-02-2013    16:10:21    Local0.Emerg    182.9.200.70    67856: 085268: Oct  2 16:11:24 GMT: %IOSXE-0-PLATFORM: 1 process wcm: *apfReceiveTask: %AVL-0-TREE_FULL_ENTRY_DOES_NOT_EXIST: AVL tree 0x12c76268 is full. Entry is not present in AVL tree.
10-02-2013    16:10:21    Local0.Error    182.9.200.70    67857: 085269: Oct  2 16:11:24 GMT: %IOSXE-3-PLATFORM: 1 process wcm: *apfReceiveTask: %APF-3-MOBILE_SEARCH_ENTRY_CREATE_FAIL: Could not add client  D857.EF76.CA87  AuditSessionID: b609c846524c45ab0000244f w/ IP 192.168.9.158: list is full.
10-02-2013    16:10:21    Local0.Emerg    182.9.200.70    67858: 085270: Oct  2 16:11:24 GMT: %IOSXE-0-PLATFORM: 1 process wcm: *apfReceiveTask: %AVL-0-TREE_FULL_ENTRY_DOES_NOT_EXIST: AVL tree 0x12c76268 is full. Entry is not present in AVL tree.
10-02-2013    16:10:22    Local0.Error    182.9.200.70    67859: 085271: Oct  2 16:11:24 GMT: %IOSXE-3-PLATFORM: 1 process wcm: *apfReceiveTask: %APF-3-MOBILE_SEARCH_ENTRY_CREATE_FAIL: Could not add client  D857.EF76.CA87  AuditSessionID: b609c846524c45ab0000244f w/ IP 10.32.127.131: list is full.
10-02-2013    16:10:23    Local0.Emerg    182.9.200.70    67860: 085273: Oct  2 16:11:25 GMT: %IOSXE-0-PLATFORM: 1 process wcm: *apfReceiveTask: %AVL-0-TREE_FULL_ENTRY_DOES_NOT_EXIST: AVL tree 0x12c76268 is full. Entry is not present in AVL tree.
10-02-2013    16:10:24    Local0.Error    182.9.200.70    67861: 085274: Oct  2 16:11:25 GMT: %IOSXE-3-PLATFORM: 1 process wcm: *apfReceiveTask: %APF-3-MOBILE_SEARCH_ENTRY_CREATE_FAIL: Could not add client  D857.EF76.CA87  AuditSessionID: b609c846524c45ab0000244f w/ IP 192.168.9.158: list is full.
10-02-2013    16:10:28    Local0.Emerg    182.9.200.70    67862: 085275: Oct  2 16:11:31 GMT: %IOSXE-0-PLATFORM: 1 process wcm: *apfReceiveTask: %AVL-0-TREE_FULL_ENTRY_DOES_NOT_EXIST: AVL tree 0x12c76268 is full. Entry is not present in AVL tree.
10-02-2013    16:10:28    Local0.Error    182.9.200.70    67863: 085276: Oct  2 16:11:31 GMT: %IOSXE-3-PLATFORM: 1 process wcm: *apfReceiveTask: %APF-3-MOBILE_SEARCH_ENTRY_CREATE_FAIL: Could not add client  3415.9E52.B214  AuditSessionID: b609c846524c45b300002450 w/ IP 192.168.9.153: list is full.
10-02-2013    16:10:29    Local0.Emerg    182.9.200.70    67864: 085277: Oct  2 16:11:31 GMT: %IOSXE-0-PLATFORM: 1 process wcm: *apfReceiveTask: %AVL-0-TREE_FULL_ENTRY_EXISTS: AVL tree 0x12c76268 is full. Entry is already in AVL tree.
10-02-2013    16:10:29    Local0.Emerg    182.9.200.70    67865: 085278: Oct  2 16:11:31 GMT: %IOSXE-0-PLATFORM: 1 process wcm: *apfReceiveTask: %AVL-0-TREE_FULL_ENTRY_DOES_NOT_EXIST: AVL tree 0x12c76268 is full. Entry is not present in AVL tree.
10-02-2013    16:10:29    Local0.Error    182.9.200.70    67866: 085279: Oct  2 16:11:31 GMT: %IOSXE-3-PLATFORM: 1 process wcm: *apfReceiveTask: %APF-3-MOBILE_SEARCH_ENTRY_CREATE_FAIL: Could not add client  3415.9E52.B214  AuditSessionID: b609c846524c45b300002450 w/ IP 192.168.9.153: list is full.
10-02-2013    16:10:29    Local0.Emerg    182.9.200.70    67867: 085280: Oct  2 16:11:31 GMT: %IOSXE-0-PLATFORM: 1 process wcm: *apfReceiveTask: %AVL-0-TREE_FULL_ENTRY_EXISTS: AVL tree 0x12c76268 is full. Entry is already in AVL tree.
10-02-2013    16:10:29    Local0.Emerg    182.9.200.70    67868: 085281: Oct  2 16:11:31 GMT: %IOSXE-0-PLATFORM: 1 process wcm: *apfReceiveTask: %AVL-0-TREE_FULL_ENTRY_DOES_NOT_EXIST: AVL tree 0x12c76268 is full. Entry is not present in AVL tree.
10-02-2013    16:10:29    Local0.Error    182.9.200.70    67869: 085282: Oct  2 16:11:31 GMT: %IOSXE-3-PLATFORM: 1 process wcm: *apfReceiveTask: %APF-3-MOBILE_SEARCH_ENTRY_CREATE_FAIL: Could not add client  3415.9E52.B214  AuditSessionID: b609c846524c45b300002450 w/ IP 192.168.9.153: list is full.
10-02-2013    16:10:48    Local0.Emerg    182.9.200.70    67870: 085283: Oct  2 16:11:51 GMT: %IOSXE-0-PLATFORM: 1 process wcm: *apfReceiveTask: %AVL-0-TREE_FULL_ENTRY_DOES_NOT_EXIST: AVL tree 0x12c76268 is full. Entry is not present in AVL tree.
10-02-2013    16:10:49    Local0.Error    182.9.200.70    67871: 085284: Oct  2 16:11:51 GMT: %IOSXE-3-PLATFORM: 1 process wcm: *apfReceiveTask: %APF-3-MOBILE_SEARCH_ENTRY_CREATE_FAIL: Could not add client  D857.EF76.CA87  AuditSessionID: b609c846524c45ab0000244f w/ IP 10.32.127.131: list is full.
10-02-2013    16:11:06    Local0.Emerg    182.9.200.70    67872: 085285: Oct  2 16:12:09 GMT: %IOSXE-0-PLATFORM: 1 process wcm: *apfReceiveTask: %AVL-0-TREE_FULL_ENTRY_DOES_NOT_EXIST: AVL tree 0x12c76268 is full. Entry is not present in AVL tree.
10-02-2013    16:11:07    Local0.Error    182.9.200.70    67873: 085286: Oct  2 16:12:09 GMT: %IOSXE-3-PLATFORM: 1 process wcm: *apfReceiveTask: %APF-3-MOBILE_SEARCH_ENTRY_CREATE_FAIL: Could not add client  D857.EF76.CA87  AuditSessionID: b609c846524c45ab0000244f w/ IP 192.168.9.158: list is full.
Any ideas?
thank you
Hall of Fame Super Gold
Your 3850 should be fairly new.  Create a TAC Case.
Community Member
I see exactly the same messages in my log on our new 3850. Any updates on this issue?
Community Member
HI Christopher,
that is what i got from Tac:
" This issue is caused by a mem leak when the clients roam. It eventually consumes the whole table available for roaming clients and starts generating these messages"
After discussion with development it turns out we're facing CSCuj21381.
>>> This is fixed in release 3.3(0)SE which is already available for download.
Community Member
With what IOS version your Catalyst 3850 is running where you are seeing these messages?
And would it be possible to post some more details about the bug? I'm not able to take a look in it.
thx!
Community Member
the software version i'm currently running  03.02.01.SE.
Otherwise, i posted all i got from tac.
I asked the engineer for more details but no succeeed. He just recommend me to upgrade to release 3.3(0)SE.
That's all.
Have to say that everything is working ok.
Bye
648
