01-19-2007 10:01 AM - edited 03-05-2019 01:53 PM
I believe I can add a WS-X4148-RJ blade to an empty slot in the 4006 without powering down the switch. Can you confirm? URL? Thanks.
Solved! Go to Solution.
01-19-2007 12:41 PM
Yes that is correct , just plug it in and then configure it the way you want it .
01-19-2007 12:41 PM
