4006 IOS question
Can anybody please show me where I can download an IOS for a Sup3 on a 4006. The main download links only send me to old CatOS images for a Sup1 and 2.
Thanks!
Hall of Fame Super Bronze
Re: 4006 IOS question
You can't run IOS on 4006 switches. You need to upgrade the chassis to a 4500 series with Sup II+, III, IV or V.
I currently have a Sup III installed in a 4006 chassis with an older IOS image loaded in it. When I follow the "Download Software" links from the main page, I can find the 4006 in that folder heirarchy thing, however it takes me to images for the old SUP I and II.
I can't find any links on cisco.com for IOS images for the SupIII. Any help/links is appreciated!
I Always use the Cisco Feature Navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Search by Feature
or
Search by Platform
NOTE: But as Edison has said it should be 4500 with Sup3.
HTH,
Mohammed Mahmoud.
Actually i've searched and 4006 with sup3 runs IOS:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/8aew/configuration/guide/l3_int.html
HTH,
Mohammed Mahmoud.
So in the "feature navigator" can I use the IOS images from the "CAT4500-SUP3" option for use in my 4006?
Yes go ahead as they both use WS-X4014.
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_tech_note09186a008063c36f.shtml
Supervisor Engine III (WS-X4014) is supported on these Chassis: 4006, 4503, 4506.
HTH,
Mohammed Mahmoud.
It sounds like you have a 4506, not a 4006. Can you post a show ver ?
Now I'm confused. It is definitely a 4006. The chassis has 4006 printed on it and the sh ver confirms it. Here's a copy of my sh ver:
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5S-M), Version 12
.2(25)EWA8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 24-Jan-07 15:18 by pwade
Image text-base: 0x10000000, data-base: 0x114EECF0
ROM: 12.1(12r)EW
Dagobah Revision 55, Swamp Revision 16
xxx uptime is 3 weeks, 20 hours, 31 minutes
System returned to ROM by reload
System restarted at 02:39:06 KLT Wed May 30 2007
System image file is "bootflash:cat4000-i5s-mz.122-25.EWA8.bin"
cisco WS-C4006 (MPC8245) processor (revision 7) with 262144K bytes of memory.
Processor board ID FOX0731002C
MPC8245 CPU at 300Mhz, Supervisor III
Last reset from Reload
4 Virtual Ethernet interfaces
32 FastEthernet interfaces
40 Gigabit Ethernet interfaces
467K bytes of non-volatile configuration memory.
and heres part of a show modules:
Chassis Type : WS-C4006
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 2 Supervisor III 1000BaseX (GBIC) WS-X4014 xxx
Ah, you have WS-X4014. That Supervisor is the same from a 4503/4506 switch.
Go to
http://www.cisco.com/kobayashi/sw-center/
Click on Cisco IOS Software
Select IOS 12.2 Release
Select CAT4500 Sup3
On, the feature navigator, choose 4506 with sup 3 and you'll get your IOS (4006 uses the same IOS as the 4506).
Give it a try and feed us back.
Note: I think that what you are using is the latest code.
HTH,
Mohammed Mahmoud.
Just wanted to let you guys know that it worked like a charm!
Thank you very much for your help!
Chris
336
