4006 - Sytem conversion CatOS to IOS
I need to upgrade a Catalyst 4006 from CatOS to IOS.
I have some doubt.
Is it possible? Wich are the rquirements? Wich is the procedure? Any issues?
Thanks in advance
Enrico
2 ACCEPTED SOLUTIONS
Re: 4006 - Sytem conversion CatOS to IOS
Hi Enrico,
You cannot convert from CATOS to IOS on Cat4006.
SUP 1 & Sup 2 on Cat4000 switch only supports CATOS and NOT IOS.
Ankur
*PLs rate all helpfull post
The Catalyst 4500/4000 Series Supervisor II-Plus, III, IV and V runs Cisco IOS? software only, and does not run Catalyst OS software. While Supervisor 1 and 2 runs only CatOS and can't be converted.
HTH, please rate if it does help,
Mohammed Mahmoud.
Hi Enrico,
Ankur
Mohammed Mahmoud.
404
