06-19-2012 06:48 AM - edited 03-07-2019 07:19 AM
I want to bring up 40G interface between two nexus 3064 over the fiber but it's not coming up. Have configured the switch for 48*10G and 4*40G. I'm using QSFP on both the switches, OM3 straight fiber cable with MPO connector. The interfaces are not coming up. Notably, it comes up with Coax 3M cable. So it's fine with coax but not with fiber. Will appreciate any help. Thanks.
06-19-2012 12:34 PM
Since you are using OM3 fiber, are your 40Gig optics Multimode?
06-20-2012 09:00 AM
Yes. We are using the 40G-SR4 transceiver. Output below from the switch:
# sh int ethernet 1/49 transceiver de
Ethernet1/49
transceiver is present
type is 40Gbase-SR
name is CISCO-AVAGO
part number is AFBR-79E4Z-CS1
revision is 02
serial number is AVP1606S271
nominal bitrate is 10300 MBit/sec
Link length supported for 9/125 um fiber is 5000 m
Link length supported for 50/125um fiber is 300 m
cisco id is --
cisco extended id number is 16
Transceiver Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 25.63 C N/A N/A N/A N/A
Voltage 3.30 V N/A N/A N/A N/A
Current 0.00 mA N/A N/A N/A N/A
Tx Power -1.33 dBm N/A N/A N/A N/A
Rx Power N/A N/A N/A N/A N/A
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
