Community Member
40G ports on nexus 5k
hi all ,
in datasheet of nexus 5k, below is written
Four port QSFP Ethernet module that provides 4 40 Gigabit Ethernet ports using QSFP interface. Each QSFP 40GE port can only work in 4x10G mode and supports DCB and FCoE.
does it mean we cant use 40G ports by themselves, is it necassary to convert them to 10g ?
Community Member
To restate this question more
To restate this question more specifically, I would like to connect a QSFP-40G-SR-BD module to a SFP-10G-SR at 10G speed.  Is that possible?
VIP Super Bronze
Yes, it is.  To convert from
Yes, it is.  To convert from one 40Gig to multiple 10Gig, you need a breakout cable.
see figure-21 in this link:
https://www.cisco.com/c/dam/en/us/products/collateral/switches/nexus-9000-series-switches/white-paper-c11-729384.pdf
Community Member
Or use a "CVR-QSFP-SFP10G"
Or use a "CVR-QSFP-SFP10G"  QSFP to SFP+ converter module?  Then put the SFP-10G-SR into that module.  That should convert the QSFP 40Gb port to an SFP+ 10Gb port.  Correct?
VIP Super Bronze
That is correct.  I have
That is correct.  I have personally never used CVR-QSFP-SFP10G adapter.
VIP Super Bronze
John,I could be wrong, but I
John,
I could be wrong, but I think the what the statement is trying to say is if you want to use the 40Gig interfaces as FCoE ports, they have to be broken in 10gig ports.  But if you want to use them as regular Ethernet ports you should be able to use them as 40Gig.
Maybe you can verify that with your Cisco sales engineer.
321
