4232-L3 blade not enabling the DHCP IP helper address as required
Am facing an issue with respect to the DHCP not releasing IP, though i have a proper Ip-helper address being configured under the interface gig 3.7 for Vlan-4.Am also attaching the config for more refernce.I was able to ping the DHCP server.I have checked from the DHCP server end as well wherin the pools were also configured fine.Kindly suggest if there is any bug pertaining to this module.
interface GigabitEthernet3.7
description *** Vlan 4 - Dealing room ***
encapsulation dot1Q 4
ip address 10.134.4.2 255.255.254.0
ip access-group 150 in
ip access-group 150 out
ip helper-address 10.134.0.81
no ip directed-broadcast
standby 4 priority 110 preempt
standby 4 ip 10.134.4.1
ip redirect
bridge-group 10
regards.Jithesh
1 ACCEPTED SOLUTION
Re: 4232-L3 blade not enabling the DHCP IP helper address as req
Hi. Have you tried disable this line in your configuration: "no ip forward-protocol udp".
Because ip helper address is to forward packets UDP.
http://www.cisco.com/univercd/cc/td/doc/product/software/ssr83/rpc_r/48383.htm#xtocid670625
Good Luck, and I hope to help you.
Paulo Mauricio
Can u enable the ports in ur access-list which are used for dhcp .i.e 67 and 68 and check.BTW these are udp ports.
Mahmood
Hi Mahmood,
During the activity we had even excluded the acl's and tried still we were getting the same error.Would it be an issue related to the catos.
regards...jithesh
We have the version cat4232-in-mz.120-25.W5.27a.bin running in the module.
regards..jithesh
Paulo Mauricio
This seems to be a good suggestion, we shall surely try this option and let you know.
Thanks ..jithesh
251
