4500 and 6500 power supply related questions
Dear friends,
I have a 4510-R-E switch with two 4200W power supplies operating in redundant mode.
Each 4200W power supply has two AC inputs.
Looking at the docs, i see that "each power supply operates at 50% capacity and provides
the same total power as a single power supply – if one fails, the backup reverts to
providing 100% power".
So, if i have two power sources viz. UPS A and UPS B. How should i connect power to the switches?
1. Power Supply 1
AC Input 1 - UPS A
AC Input 2 - UPS B
2. Power Supply 2
AC Input 1 - UPS A
AC Input 2 - UPS B
(OR)
1. Power Supply 1
AC Input 1 - UPS A
AC Input 2 - UPS A
2. Power Supply 2
AC Input 1 - UPS B
AC Input 2 - UPS B
Also for the 6500 with 6000W (2 AC inputs) , can you tell me if i should connect the same way?
I know that power supply failure will not be a problem. My concern is that if UPS A fails, then the power supplies should still continue to run at their rated capacity and not at half the capacity.
Thanks a lot
Gautam
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: 4500 and 6500 power supply related questions
Gautam,
I would do the same for 4500 if you have multiple outputs for each power supply.
Good Luck
Reza
VIP Super Bronze
Hi Gautam,
We use 6500 with 6000W power supply and connect them just like your 1st option.  It works well.
Reza
Dear Reza,
Thanks a lot. So you mean that you connect the AC inputs of each power supply to different sources and it works fine for you
VIP Super Bronze
Yes, each inputs of each power supply to different power sources
Reza
Thanks a lot Reza. What about 4500? Should we follow the same approach for 4500 as for the 6500.
VIP Super Bronze
Gautam,
Good Luck
Reza
362
