01-14-2014 04:12 PM - edited 03-07-2019 05:33 PM
Hi all,
I was reading today that Cisco Release IOS XE 3.4.0SG does not support Layer 3 MEC on the 4500 platform.
I would like to configure my MEC and run OSPF on my UPLINK. I would also like to prioritise 1 uplink over the other.
Would something like this work or can someone recommend a better solution not too sure abut the ospf cost.
thank you
SWITCH-VSS(config)#interface Port-channel 10
SWITCH-VSS(config-if)#switchport
SWITCH-VSS(config-if)#switchport mode trunk
SWITCH-VSS(config-if)#switchport nonegotiate
SWITCH-VSS(config-if)#switchport trunk allowed vlan 100
SWITCH-VSS(config)#interface range gigabitEthernet 1/2/48, gigabitEthernet 2/2/48
SWITCH-VSS(config-if-range)#switchport
SWITCH-VSS(config-if-range)#switchport mode trunk
SWITCH-VSS(config-if-range)#switchport nonegotiate
SWITCH-VSS(config-if-range)#switchport trunk allowed vlan 100
SWITCH-VSS(config-if-range)#channel-group 10 mode desirable
SWITCH-VSS(config)#interface port-channel 15
SWITCH-VSS(config-if)#switchport trunk allowed vlan 105
SWITCH-VSS(config-if)#interface range gigabitEthernet 1/3/48, gigabitEthernet 2/3/48
SWITCH-VSS(config-if-range)#switchport trunk allowed vlan 105
SWITCH-VSS(config-if-range)#channel-group 15 mode desirable
SWITCH-VSS(config)#interface vlan 100
SWITCH-VSS(config-if)#ip address 10.0.0.1 255.255.255.252
SWITCH-VSS(config-if)#int vlan 105
SWITCH-VSS(config-if)#ip address 10.0.0.5 255.255.255.252
SWITCH-VSS#conf t
Enter configuration commands, one per line. End with CNTL/Z.
SWITCH-VSS(config)#router ospf 100
SWITCH-VSS(config-router)#router-id 10.10.10.10
SWITCH-VSS(config-router)#log-adjacency-changes
SWITCH-VSS(config-router)#nsf
SWITCH-VSS(config-router)auto-cost reference-bandwidth 1000
SWITCH-VSS(config-router)#network 10.0.0.0 0.0.0.3 area 0
SWITCH-VSS(config-router)#network 10.0.0.4 0.0.0.3 area 0
SWITCH-VSS(config-router)#passive-interface default
SWITCH-VSS(config-router)#no passive-interface port-channel 10
SWITCH-VSS(config-router)#no passive-interface port-channel 15
SWITCH-VSS(config-router)#no passive-interface vlan 100
SWITCH-VSS(config-router)#no passive-interface vlan 105
SWITCH-VSS(config-router)#^Z
SWITCH-VSS(config)#int vlan 100
SWITCH-VSS(config-if)#ip ospf cost 10
SWITCH-VSS(config-if)#ip ospf cost 100
01-14-2014 04:21 PM
I am not sure if OSPF priorities will work that way since you assigned them to vlan interfaces instead of the portchannel interfaces
What device are you connecting the VSS pair to?
01-14-2014 04:34 PM
Cisco 3550
01-14-2014 04:32 PM
Serge
As Reza says it would be useful to know what devices are connected to the 4500 via these two etherchannels.
I believe you can use OSPF cost on the SVIs so it may well work but some more information would be helpful. I should also say i am talking in general about using cost on an SVI and Reza has far more experience with VSS than i do so i may well be wrong.
Jon
01-14-2014 04:41 PM
Cisco 3550, I'm not sure of the IOS unfortunatly I don't have access to them and they are asking for ospf.
OSPF will be running in the 3550 facing my VSS switch and BGP on the wan side.
I will be running EIGRP on my LAN and OSPF to the 3550.
01-14-2014 04:47 PM
So you are having two etherchannels to the same device ?
I'm just not sure why you are using two etherchannels as one should give you the redundancy ie. if one of the 4500s goes down you still have the connection from the 3550 to the other 4500.
Again though, like i say it could be due to may lack of knowledge in terms of VSS.
Hopefully Reza can add to this.
Jon
01-14-2014 05:04 PM
01-14-2014 05:07 PM
That makes more sense.
I think applying cost to the SVI should work but the obvious problem is that if one link in the active MEC fails because the cost is applied to the SVI it will probably still favour that remaining link.
That would only be applicable if the actual link went down though ie. if the switch crashed then the other MEC only has one link available anyway.
Jon
01-14-2014 05:37 PM
I have never tested VSS with priority on the SVI. I have only done it with layer-3 MEC with IP address on the Etherchannle. If the priority does not work for you, you can simply let OSPF do equal cost load balancing. You also need a layer-3 link between the 3550s.
01-15-2014 12:47 PM
ok thanks, I will try it next week
