07-05-2013 02:46 AM - edited 03-07-2019 02:14 PM
Hi All,
I need to troubeshoot memory on IOS XE (sup7-e) for 4500 switch. I found low amount of free memory for process and has to reload switch to recover. Does anyone help to guide me about command have to use? I'm not familiar to use command on IOS XE version and not sure the set of command below is enough to find out the cause.
show memory
show process memory sorted
show processes memory detailed process iosd sorted
07-05-2013 03:32 AM
Following are the commands: -show process memory-show proc mem det proc iosd sort
-show process memory sorted -show memory allocating-process totals
Inayath
07-05-2013 03:46 AM
Hi Inayath,
Thanks for sharing. A command 'show memory allocating-process totals' is not vaild. Do you mean 'show memory detail process iosd allocating-process totals'? Note, i use 03.03.0SG version.
