4500 Switch - Unsupported Module
nassar
I am getting an ' unsupported module' message on 4503 switch for a WS-X4648-RJ45V-E module. Slot 1 has supervisoe V module installed (WS-X4516). The IOS is 12.2(50)SG. Is the module supported in this configuration.
5 Replies 5
Mohamad Qayoom
Level 3
Level 3
What power supplies are you using?
Mark Yeates
Level 7
Level 7
I believe you are going to need a sup6-E/E chassis for that particular module to be supported. You are using a supV and I believe the "E" modules must be used with the sup6.
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea_ps4324_Products_Data_Sheet.html')">http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea_ps4324_Products_Data_Sheet.html
HTH,
Mark
Edison Ortiz
You need a 4503-E Switch.
If you just purchased this module, return it and get WS-X4548-GB-RJ45V
HTH,
__
Edison.
The chassis is a 4503-E. Is 4648 supported with SUP V?
You need the Sup6-E as well. See the following document:
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea.html
As I recommended, you can return this module for WS-X4548-GB-RJ45V and it should work under your current hardware.
HTH,
__
Edison.
