03-25-2014 11:01 AM - edited 03-07-2019 06:51 PM
Is it possible to run VSS on 2 4500-X switches of different port counts? For example a 24 port 4500-X and a 32 port 4500-X paired into a VSS cluster?
Solved! Go to Solution.
03-25-2014 02:37 PM
Yes.
See this excerpt from the following link:
Best-in-Class Resiliency
The Cisco Catalyst 4500-X Series is designed for excellent nonstop communications with non-interrupted hardware switching. With Cisco IOS XE Software, customers continue to reap the benefits of this best-in-class resiliency in various ways.
In addition to redundant power supplies and fans, the Cisco Catalyst 4500-X is Virtual Switching System (VSS).
Any two Cisco Catalyst 4500-X Series Switches can be pooled together into a VSS. The two switches are connected with 10 Gigabit Ethernet links called Virtual Switch Links (VSLs). Once a VSS is created, it acts as a single virtual Cisco Catalyst switch delivering the following benefits:
03-25-2014 02:37 PM
Yes.
