4500X bugs...
We have a WS-C4500X-32 and have recurring problems with it:
If the port of entering the LACP Port-channel pull out module or disconnect fiber, then after some time the port hangs with the message
"%C4K_HWPORTMAN-3-TXQUEDRAINFAILURE: Failed to drain transmit Failed to drain transmit queues on Switch Phyport Te1/XX using slot pool 65535" and after return back this port does not send traffic. Corrected only reboot.
How without reboot withdraw port out of this state?
And today rebooted with the following diagnosis after a few weeks of working:
Sep  2 16:36:00: %SYS-3-INVMEMINT: Invalid memory action (malloc) at interrupt level
-Traceback= 1#30b33d0f1b99e378ef2c80c83b545634
Sep  2 16:36:00: %SYS-2-MALLOCFAIL: Memory allocation of 448 bytes failed from 0x151CBCC4, alignment 0
Pool: Processor  Free: 543332960  Cause: Interrupt level allocation
Alternate Pool: None  Free: 0  Cause: Interrupt level allocation
-Process= "<interrupt level>", ipl= 2, pid= 86
Sep  2 16:36:00: %PRST_IFS-3-FILEMEM: No memory to update nvram:persistent-data. Please free some space Early Notification of a Critical job [iosd] exiting abnor mally! Initiating cleanup sequence.
Please stand by while rebooting the system...
Restarting system.
What to do?
IOS XE 3.4.0SG (cat4500e-universal.SPA.03.04.00.SG.151-2.SG.bin)
So far from December 2012 for this switch was not updates?
  • LAN Switching and Routing
Everyone's tags (2)
1 REPLY
Hall of Fame Super Gold
Re: 4500X bugs...
Seems to me this is the kind of trouble that you should bring to the TAC.
700
